ZF-650 2WD Manual Transmission Partout
For Sale1999 Ford F-250 Super Duty
Description:
I purchased a core ZF-650 (ZF6) manual transmission from a 7.3L 2WD vehicle. I only needed the main case (bellhousing). I am selling the following used parts right now:
Output flange $50
Main shift detent $30
Countershaft assembly with cluster gears $200
Main shaft $150
Various shift forks, shift rails, gears, needle bearings, synchro hubs, etc.
| Picture | Title | Part Category | Price | Part Description |
Extension housing 2WD | Drivetrain | $200 | Contains old seals and bearings. Reverse idler gear included. Reverse switch is broken. |
Output flange | Drivetrain | $50 | I plan to include the nut with the main shaft, but if for some reason you need it just let me know. |
Main shift detent | Drivetrain | $30 | Detent and threaded retainer. Apply liquid PTFE sealant to threads before install. |
