99-04 axles and wheels
For Sale
Wheels and Tires/Axles
  • Wheels and Tires/Axles - 99-04 axles and wheels - Used - 1999 to 2004 Ford 1 Ton Pickup - Rochester, IL 62563, United States
    Expired
    Expired
    Expired
  • Price
    $1,000
    • OBO
  • Location Rochester, IL, 62563, USA
  • Condition Used
  • Compatibility
Make Model Year
Ford 1 Ton Pickup 1999 - 2004
Description:
Front and rear axle from my 2000 F350. Front axle has year old calipers and pads, I believe the hubs are just a little older, has aftermarket rotors. Rear axle is untouched other than new pads, its an open diff. Axles had 368,101 miles on them when removed. Comes with everything needed for the front axle(, sway bar, x code leafs, steering gear box, spring mounts and shackles), rear axle and all 5 factory wheels. The aluminum wheels need cleaned up, clear is peeling off, plasti dipped currently. Tires will be removed from all wheels
