2020 Ford F250 OEM Super Duty Console F250 17-20
For SaleInterior/Upholstery
Description:
This is a console I just removed from my 2020 Ford F250 Tremor to install a floor shifter. Most of the parts are 2020, but a couple are 2018 because I used the original pieces which include the back panel, and the front box compartment that has the USB ports. What you see is included and this has the sliding cup holders going from 2 to 4 on the front, dual cup holders for the rear, air vents, etc. Main center console compartment has 12 volt charge port, front compartment has two USB ports and a light, rear panel has 110 plug, two USB ports and a 12 volt charger. It comes with some wiring, but you will need the harness appropriate for your truck. It should fit 2017 to 2020 F250 and F350 if you are looking to replace jump seat with a nice console. Truck only has 1400 miles on it, this is like new. Please let me know any questions $650 and located in Linden, Michigan which is about an hour North of Detroit and hour East of Lansing.
