94 F150 5.0L w/4R70W Parts!
For Sale1994 Ford F-150
Description:
All parts pulled from a running 150k km truck i picked up for an engine pull for my rebuild project.
1994 F150 5.0L w/4R70W auto trans
First up is
Complete harness from PCM Connector to trans, neutral safety switch, t case. Pin to pin tested for continuity and short to ground
No splices all original.
$50 plus shipping from Alberta
| Picture | Title | Part Category | Price | Part Description |
94 F150 5.0l w/4r70w Functional PCM | Engine - Electrical | $80 | HUG2 PCM from 1994 f150 5.0l with 4r70w auto trans. Pulled from running conditon truck with low kms as a donor vehicle for my rebuild project. $80 + shipping from Alberta See the pics for full Ford code. Slight plastic chip from connection case. Does not affect function. |
Fuel Injector Top Block Harness | Engine - Electrical | $60 | Complete and serviceable upper fuel injection and electrical sensor harness. $60 + shipping from Alberta |
PCM connector harness complete | Engine - Complete | $40 | Complete and good shape PCM connector harness cut back right to fuse box. $40 + shipping from Alberta |
Air/Smog Pump | Engine - Exhaust | $40 | Fully functional air/smog pump and pulley OEM FoMoCo part $40 + Shipping from Alberta |
AC Pump and Clutch | Miscellaneous | $40 | Functioning OEM FoMoCo AC and clutch assy $40 + shipping from Alberta |
