1981 F100 302 Oil Indicator, Tube Assy & Bracket
Wanted
Miscellaneous
  • Miscellaneous - 1981 F100 302 Oil Indicator, Tube Assy & Bracket - New or Used - Chickasaw, AL 36611, United States
    Expired
    Expired
  • Price
    Any Price
  • Location Chickasaw, AL, 36611, USA
  • Condition New or Used
Description:
I am looking for the dip stick, tube, and bracket for an 81 F100 302. The bracket may be made on the tube as Number Dummy indicated from the parts book but it list one as well. If anyone may have some or all of these parts laying around from changing motors out and such I would be interested in them. This should be for the one that mounts around cylinder 7. Thinking it should look like whats in the pictures below. I have been able to find the dip stick but not the tube by searching online so if you have the tube only I would be interested. I found two listing for the tube on rear counter but they are not available. No need in buying the dip sticks I have found if I can't locate the tube to match it.
Indicator Oil Level: E3TZ 6750L #E3TE-CA
Tube Assembly: E2TZ 6754-A
Bracket (Oil Ind Tube): E0TZ 6786-A
