COATS 1001 tire/wheel balancer (240v single phase power)
For SaleMiscellaneous
Description:
I'm selling a working COATS 1001 wheel balancer. It is a working machine, with all the proper taper cone adapters, springs and shaft hub tightening wingnut.
This is a 240v single phase machine, so you can use it on standard residential power, in your garage or barn. I upgraded to a machine that will do industrial and Semi truck tires, and no longer need this one
$425.00 Located @ 49423
