'96 F250, 7.5L (460), 4WD, Auto, Crew Cab, Short Bed
For Sale1996 Ford F-250
Price
$7,000
- Location Stuart, FL, 34997, USA
- Condition Used
- VIN 1FTHW26G7TEB77525
- Mileage 238,000
- Engine 8 cyl
- Drive Type 4WD
- Transmission Automatic
- Vehicle Type Truck
- Exterior Color Black
Description:
The Good: Adult Daily Driven since/during major refresh 8 years ago ~2,800 mi per year, clean title, all receipts (238K on odometer)
The Bad: Kenwood receiver starting to act up; detachable face occasionally cutting out. Headliner starting to loosen in rear corners.
The Ugly: Passenger side drip rail rust. Been addressed once 2.5 years ago, but coming back. Rather sell as-is you can see for yourself.
Along the way: American Force Alum wheels (no spacers, no rubbing) with Toyo Open Country Tires (37x13.5x22). Have re-painted, new bumpers, headliner, professionally installed 600 watt stereo system w/ shallow 12" sub, rebuilt tranny/transfer case, replaced A/C, oil pump, Wet Okole wet suit seat covers, both fuel pumps, window tint, radiator, belt tensioner, clutch fan, power steering, upper/lower ball joints, custom 3/0 SGX battery cables w/ 3/8 lugs, master cylinder, calipers, vacuum booster, front bearings/races, rotors, pads, drums, shoes, wheel cylinders, U-joints, cap/rotor, steering box, starter, windshield washer pump, wiper arm bushings, front leaf spring bushings, shackle bushings, carrier bearing, shocks, struts, all tie rod ends, stainless brake lines, windshield, double roller timing chain/cover, water pump. All receipts. Thanks for looking.
