TCI 427500 C6 Transmission Low Gear Planetary
For SaleDrivetrain
Description:
Ordered this kit for my C6 rebuild, it took so long to deliver I got parts elsewhere, then it showed up. Its new in box, I opened box just to confirm its contents, I did not open the inner sealed packaging. Below is TCI's description.
The new TCI® Ford C6 6-Pinion Low Drag Planetary delivers a wealth of improvements over competitive conventional 4-pinion systems, including greater strength and significantly lower drag through the use of low friction, high-quality bearings that replace standard brass thrust washers. In addition, the new planetary incorporates a 2.72:1 first gear and 1.54:1 second gear to greatly improve drag strip launches and better overall performance. TCI®, the leader in the development of advanced automatic transmission components, developed the 6-pinion design after significant field testing with the popular Ford C6 transmissions, which have been historically plagued by high internal parasitic drag. The new TCI® planetary system greatly reduces the drag and allows Ford-equipped vehicles to benefit from the high strength of these transmissions without the horsepower drain.
FREE SHIPPING ! and its heavy...
