Ford V and Modified B Code Springs and Hardware
For SaleSteering/Suspension
Description:
I pulled these off axles I bought from a member in hopes to put them under my Excursion but decided to buy new springs since I have a heavy aftermarket front bumper. They had a couple of years use on a 7.3 Excursion before I bought the full axle assemblies from a donor truck.
These are Ford springs and I have the hardware and blocks as well if you need them. You will need to purchase are new u bolt kits since they are not reuseable (torque to yield) on these trucks. I got mine for about $70 per axle from ATS Springs. You will also want new spring pack bolts for the B codes which can be purchased for about $15 a pair.
