1994 F-250 set up for camping and road trips
For Sale1994 Ford F-250
Price
$3,500• OBO
- Location Tucson, AZ, 85631, USA
- Condition Used
- VIN 1fthx25h0rka97968
- Mileage 234,000
- Engine 8 cyl
- Drive Type 2WD
- Transmission Manual
- Vehicle Type Truck
- Exterior Color Other
Description:
This truck has a strong-running 351 engine. There are no leaks, it doesn't use any oil, and there's no blowby. ZF 5-speed transmission. Cold air con, power locks and windows, cruise control. The back has a carpeted interior and a place to sleep with storage underneath for when you're camping out or going on trips. All maintenance is up to date, and done by me to a high standard (I'm an airplane mechanic).
Front and rear brake pads, shoes, drums, rotors, and front bearings are all new.
New distributor, coil, ignition module, plugs, and wires less than a year ago.
New parts within last 4.5 years: clutch and master/slave cylinders, brake master cylinder/calipers/hoses/wheel cylinders/ABS valve, radiator and water pump.
Anti-theft device.
Trailer hitch in back, tow hook in front.
Tires have plenty of tread and are wearing evenly.
The body looks good, inside and out, except for a bent fender behind the left rear wheel and a small rust spot behind the left door.
Color is a dark forest green.
Includes a spare good alternator and PCM.
Located near Tucson, Arizona. $3500 or best offer, cash in person only. Email greentruck at nym.hush.com
