Upper and lower shift boots 1995 F150 4.9 5 speed
For SaleDrivetrain
Description:
I replaced my shifter boot housing assembly.
It consists of the rubber boot in your cab, attached to a plastic base, and it screws through the lower rubber boot assembly into your steel floor pan.
3 of the 4 corners the plastic holes that retain the screws are broken.
But if you do not have these shifter boots and are handy, you could make this work.
I believe that is what my previous owner did. This assembly probably will work with many more years, but that is up to you to research.
$20 plus shipping, probably about $5
