PML TorqShift transmission pan 03-07 Ford 6.0L
For SaleMiscellaneous
Description:
Looking to sell a heavy-duty, thick walled aluminum transmission oil pan that was on my truck for 12 months. Has ribs for heat dissipation, magnetic drain plug, and a spot that can be drilled/tapped for temp sensor. Finish is raw aluminum with texture that looks like what you get from sand blasting. Also provides for an additional 4.5 quarts of fluid.
Comes with mounting hardware and used die-cut gasket if you want it.
Product page is here:
http://www.yourcovers.com/transpan_9973.php
