Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F600 rear wheel hub oil seal removal
Old Oct 6, 2010 | 06:40 AM
bill davis's Avatar
bill davis
F600 1982
Changing out the two-piece oil seals on the rear brake drums to unitized seals. After removing the old oil retainer and wear sleeve off the spindle. I started on removing the oil seal in the drum. I manage to pop out the inner rubber part of the seal leaving the outer shell in the drum. How do remove this part? There is no way to get any kind of tool on it to pull it. Maybe I need cut it out?
Any suggestions?
Thanks
bill
Old Oct 8, 2010 | 10:37 AM
rbaker6336's Avatar
rbaker6336
You should be able to drive it out from the other side.Worse case you my have to remove the inner bearing race first
Old Oct 8, 2010 | 04:16 PM
bill davis's Avatar
bill davis
f600 Hub oil seal removal
Thanks Ray, The outside part of the seal had no shoulder to work against. It was flush with bore of the hub.
I took it to a Ford shop and they said they never seen anything like it. Somebody went through a lot of work modifying it to take a somewhat larger seal. I gutted the seal leaving the out side rim and install the right size seal in it. The other hub had the right seal. I'm thinking that some one might mess something in the hub and had the hub turned to go to the bigger seal.
Don't know.
thanks for your response
bill
michaelshewkin
Oct 23, 2014 10:57 PM
Fyrhosr
Aug 17, 2013 05:52 PM
Groundpounder0331
Jun 20, 2010 06:28 PM
awhtx
Large Truck
Mar 25, 2010 01:35 PM
