Old electric truck horn need help wiring please
Old Aug 10, 2010 | 09:32 AM
jeremyburmeister's Avatar
jeremyburmeister
HI I have an unusual question here. I am not a vintage truck owner (YET) but I do love old things and should ultimately like to replace my modern truck with an old one to pull my travel trailer .
So the other day I an old truck horn, black tin, about 24 inches long with a heavy bulbous end to it. It has two electric connectors across the front and one at the top. I would like to hook this up and use it on my vintage style bike for a festival coming up. Does any knowledge on how to wire it up and get it working? My old mechanic said it was probably 6 volt. There are no stampings anywhere. It looks to me to be from around the 1930's-1940s. Again I will be wiring it to a bike (assuming it still works) So I will ned to mount a power source for it to...suggestion on that too please. I do have an old small crate on the back of the bike where this set up would be mounted to in all likelihood.
there are two photos in my album
may thanks for any help
Jeremy (liker of old things)
Old Aug 10, 2010 | 10:07 AM
whateg01's Avatar
whateg01
When I click on "View Gallery" it says that you have not created one.
Dave
Old Aug 10, 2010 | 11:06 AM
jeremyburmeister
images
I'll try again. It only two picture- I'm not very well versed in this forum stuff///Could I email them directly to you?
Old Aug 10, 2010 | 11:09 AM
jeremyburmeister
the photos are in my album for sure, not sure how to make that available though
Old Aug 10, 2010 | 11:10 AM
jeremyburmeister
so if you look under album it is the third one listed right now as 'horn"
Old Aug 10, 2010 | 10:28 PM
alittle40's Avatar
alittle40
If you go to "Albums" and then down to Horn, you will find the pictures that were posted.
Wiring should be simple, one wire to ground, the other wire to one side of a horn (starter push-button) button and then the other side to ground. When button is pressed, a circuit is made and the horn will blow.
Old Sep 16, 2010 | 12:07 PM
blurooster's Avatar
blurooster
the large bolts are for mounting the horn, the one one the back is for power. probably 6v pos ground.
