86 B2 2.8 to 3.0 eng swap
I know the trannys and harnesses would all have to swap as well. Will it bolt up? How hard is it to swap over the electronic stuff? thanks!
A 3.0 is a different animal from 2.8/2.9 (as you noted) even when taken out of a front-pointing application like a ranger (though as you might guess from my tagline, I'm partial to 'em). The cross-mount 3.0 from a taurus has the same block & heads, but even subtle things like the head gaskets are allegedly diffrent (cause your coolant circulates differently). Letr alone trying to
I assume you're considering this because you've got access to an almost-free taurus with a good engine. Unless you've got lots of time on your hands a fair bit of money to pour into this one to overcome obstacles as noted (and others to come) to prove you can do it, suggest you sell the taurus/engine and put the proceeds towards a more straightforward swap.
Good luck!
Edit: Sorry attention wandered. Substitute Sable for taurus in the above
