Electric fan
Old Apr 6, 2010 | 12:00 AM
AJHEATING's Avatar
AJHEATING
Electric fan
I am back to my project and I want to run a elecric fan. I have a 1975 ford F100 short bed 300 3spd manual. I dont tow anything and the way the weather is changing all around the world I couldnt tell you if it is going to get 100 degrees in the summer here in the Willamette Valley, Oregon or not. I think I will go with a 16" puller but really dont know the on/off temp to use. I have a 195 t-stat and a 3 core aluminum radiator. my gauge reads right at 190-195 when running but that is at the back of the block and I will probably mount sending unit in water pump.So would I run a 220 on 195 off or 185 on 170 off? would it be cooler at front of block? or is the temp pertty even through whole motor? Thanks
Old Apr 6, 2010 | 01:10 PM
F-250 restorer's Avatar
F-250 restorer
I too have a '75 p/u, but mine is a F-350, with F-250 emblems. Recently I had a thread running regarding my swap to a Summit 31X19 aluminum cross flow rad.
I enjoy saving $ where I can, so I used a combination of 1 extreme high cfm 14" puller with shroud, and a 12" pusher outside. Both of the fans I pulled from the junk yard.
I have that connected to a 'painless' thermo switch I bought from Summit Racing. I run a 180 thermostat, and have the fans set to kick in at 190. That allows me to cruise w/o the fans, then at a light, when it heats up, they quickly cool the engine in only about 1 minute.
FYI: I believe the sending unit at the rear of the engine is the hot spot. I tried to use a thermo. switch in the water neck, but the temp guage would always read about 20 degrees hotter than when the switch was supposed to start the fans. I tried 2 with the same result.
FYI2: Space is tight. My radiator is 2.25" thick off the bulkhead. That left only about 3" to the w/pump pulley. So choose your fan wisely. That is why a lot of guys go with a dual fan set up. It allows for some 'placement.' However, some dual fans will pull quite a bit of amps. Mine draw 25 amps, but I usually drive around with just the puller working, and that is sufficient in the winter.
