anti freeze leak
Old Feb 9, 2010 | 11:02 AM
njstevens's Avatar
njstevens
anti freeze leak
Ok i had the water pump changed twice last year ( 1st change faulty pump). Since then I have been noticing i will leak antifreeze from time to time. I only leak x amount . I can fill it to the cold max and within a day i am at the same low spot. No more no less. Anyt clues?
Old Feb 9, 2010 | 11:12 AM
JOEKILLA's Avatar
JOEKILLA
Where is the leak coming from? Water pump, hoses, etc?
Old Feb 9, 2010 | 05:23 PM
VR6Nutt's Avatar
VR6Nutt
X2 - where is the leak coming from? Check rad cap 1st, btw.
Old Feb 16, 2010 | 12:52 PM
njstevens's Avatar
njstevens
not sure . Cant see the leak for some reason. Cant alwasy get it to leak either.
Old Feb 16, 2010 | 01:12 PM
cdnalpina's Avatar
cdnalpina
I had a problem like that with my Ex. Certain angles would make it leak worse than others. Colder temperatures made it worse also. In my case, it was where the plastic part at the bottom of the rad joins the aluminium part. The seal was slowly starting to fail. Have a look in the engine, down the back face of the rad. There is a 'sill' where the plastic part mounts to the aluminium part and if it is wet that could be your culprit. Super crappy design...
Mr. Sandman
Jan 13, 2012 06:13 PM
ampslw
Jun 13, 2011 10:16 PM
sdg0080
1978 - 1996 Big Bronco
Sep 11, 2010 09:47 PM
dazman
Jun 8, 2004 11:30 PM
