2000 expidition oil pressure ??
Old Jan 18, 2010 | 11:54 AM
im2tall33's Avatar
im2tall33
hey guys.. so my dad has a 2000 eddie baurer expidition and hisoil pressure gauge is acting up.. when he starts the truck it will stay at 0 for a long time and if he hits the gas it will flick up a bit. but it wont stay up. after running for a while the gauge will start flickering around but never hold constant.. so COuld his sensore for it be bad? if so where is it so we can replace it.. thanks?
Old Jan 18, 2010 | 03:37 PM
MisterCMK's Avatar
MisterCMK
The sender is my first culprit. I have had problems with the sender on the 2000. It would act goofy when the truck was started and then once it was warmed up it usually showed oil pressure. I replaced the sender and that fixed it. Check the oil pressure to be sure though.
Old Jan 18, 2010 | 03:44 PM
im2tall33's Avatar
im2tall33
thanks.. do you know where the sender is located? thanks..
Old Jan 18, 2010 | 04:03 PM
MisterCMK's Avatar
MisterCMK
Above the front differential on the oil filter adapter. It is a bit of a bugger to replace.
Old Jan 18, 2010 | 04:15 PM
im2tall33's Avatar
im2tall33
thanks so much.. he will be thrilled..
kmack992
15
Jan 5, 2014 09:39 PM
WTFiseverynameinuse
Jan 16, 2012 09:05 PM
im2tall33
Feb 17, 2011 08:46 PM
Mydiesel250
Aug 15, 2010 10:08 PM
indebt
Jul 12, 2008 03:20 PM
