air suspension compressor noise
Old Jan 13, 2010 | 08:46 AM
87wreckerman's Avatar
87wreckerman
on a 99 navi, is it normal for the air compressor for the susp to be kinda loud and noticeable from inside the drivers seat? i dont hear it while driving but when i first start it up and am sitting idling its pretty loud, is that normal? and if your just sitting idling on flat ground how often should the compressor be kicking on and off?
Old Jan 13, 2010 | 09:39 AM
alloro's Avatar
alloro
Many people have complained of this same issue. As I recall, replacing the compressor mounting bushings significantly reduced the noise.
Old Jan 13, 2010 | 11:16 AM
87wreckerman
ok so just replace them with new stock ones or are there better ones to use? the compressor is right up under the hood on the pass side near the firewall right?
Old Jan 13, 2010 | 12:05 PM
alloro's Avatar
alloro
I would get the new ones from the dealer, after you confirm that they need replacing. Some signs to look for are cracking, brittleness, hardness, looseness, and inflexibility.
Yes, under the hood, passenger side.
Old Jan 13, 2010 | 04:21 PM
pdqford's Avatar
pdqford
I got my replacement 'isolators' from some outfit in Florida (can't recall the name). Ford also has a redisigned mount for the pump. IIRC, my Lincoln Dealer said the new mount would run about $100.
Well, on my 2002 Navi it's on the right (passenger) side behind the headlight and under the windshield washer tank. I found it easier to take the battery and battery box out so I had more room to get the windshield washer tank out, so I would have more room to get the compressor lines disconnected so I could remove the compressor. YMMV!
Old Jan 13, 2010 | 10:21 PM
87wreckerman
ok, yeah im gonna check out the compressor bushings and see if thats making the noise. i mean i dont know what they are suppose to sound like just seems a lil loud, ive had a few towncars with the air suspensions and i cant recall ever hearing the compressor in those so... also while were talking air susp's, what is in the far back drivers side of these trucks? in the compartment with the door? looks like a air compressor of some sort itself back there??
Old Jan 14, 2010 | 12:06 PM
alloro's Avatar
alloro
That's to blow up the rafts and ***** when you get to the beach.
Old Jan 14, 2010 | 08:04 PM
rhino_160's Avatar
rhino_160
there is a compressor in the rear as well on a 2000 Navi? i know where the one in the front is.
Old Jan 14, 2010 | 08:39 PM
Moto Mel's Avatar
Moto Mel
[quote=pdqford;8363459]I got my replacement 'isolators' from some outfit in Florida (can't recall the name). Ford also has a redisigned mount for the pump. IIRC, my Lincoln Dealer said the new mount would run about $100.
American air suspension in Jacksonville/Green Cove springs area, if I remember right. I dealt with him 8 or 9 years ago, I don't recall his name but he would really work to make sure you were satisfied with his
product(s).
funfunstuie
1983 - 2012 Ranger & B-Series
Apr 20, 2017 06:28 PM
IHbase
Jul 24, 2015 07:37 AM
UNCatTech
Jun 21, 2015 06:58 PM
bnradams
Nov 5, 2008 03:26 AM
racerock
17
Mar 7, 2005 08:09 PM
