Blend door motor install question
Old Nov 10, 2009 | 06:38 AM
Navdriver's Avatar
Navdriver
I am replacing the blend door motor, (and heater core), on my Navigator. Before taking everything apart, I set the temperature to the middle of the range to make it easier to put the blend door on. That means the old blend door motor was in the halfway open position, however the new motor I am putting in is in the fully open position.
When I hook everything back up and reconnect the battery, will the new blend door motor just move to the halfway position?
Old Nov 10, 2009 | 08:17 AM
alloro's Avatar
alloro
Yes it will move to the position the temperature dial on the dash tells it to move to. The only thing that will stop the motor is the linkage to the blend door if it binds.
