WooT!! Dyno Numbers
WooT!! Dyno Numbers
Well today been fun, I got my 72 on a rear wheel dyno and Im very happy with the numbers
355hp @ 3100 RPM
612FPT @ 2900 RPM![Big Grin](images/smilies/biggrin.gif)
This is from a lightly modded 427 marine engine in my 72 F-100
427 bored 10 over Decked 10, Stock Marine Cam, re-chromed Cyl walls Hi-Val Oil Pump, Oil Cooler, Reserved External Oil tank hold 5 Qts, 2 Oil Filter, OEM 4bbl Marine Intake, Edelbrock street 600 cfm carb with a 1in spacer. 180 thermostat. C6 with a B&M Towing Shift Kit, 9in rear end with 4.11 gears with a Welded diff ( Home made locker ), and 31x10.5x15 Tires.
While this isnt the most powerful, the Toque is what I was after for towing Boats and Horses.
355hp @ 3100 RPM
612FPT @ 2900 RPM
Awesome numbers...but I'm always interested in the story... where'd you find a marine 427, what is the difference compared to a "normal or standard" 427, whatever that means? compared to a 428 what did the rebuild cost you? i'm looking for for 428 for my crewcab but i've been told don't go for a cj or scj, why not? If I find a marine 427 or any other 427 should I go for it? Why or why not? What where your challenges building a marine 427, would you do it again?
Rab
Rab
I work on Boats for a living first off. I brought a Chris Craft that had 2 of the 427 in it from salvage. It came off a trailer going down the high way, destroyed the hull. The Marine block is about 100lbs heaver, Has Chromed Cyl wall. Is a true 4 bolt, Not the cross bolt like the cars/trucks. and the tranny bosses are NOT drilled or tapped. The Cyl walls are much thicker also, Marine engine are designed to work much harder the cars/truck, Unlike cars, Boats dont coast at all, You working the engine all the time. And Since this block is from Chris Craft, they also do a lot of porting and smoothing of the intake runners. All the Ports are matched. If you check In Boards engine in boats, ther Lower HP but much higher torque.
355hp @ 3100 RPM
355hp @ 3100 RPM
612FPT @ 2900 RPM
John
![Really Cool](images/smilies2/coolgleamA.gif)
winr
01-06-2007 01:09 PM
Bubba Blue
01-24-2005 03:23 PM
schweg2
08-14-2004 02:42 PM
