Sponsored by: Auxito
4.6 liter. is it enough?
Old Aug 21, 2009 | 12:06 AM
gloorm's Avatar
gloorm
I am looking at a 99 150 with a 4.6 liter. Ive heard that they aren't enough power. I plan on towing and working it hard, but my grandpas similar truck seems 2 do fine (its not a 4x4 though). It has 2 be better than my 302 with 3.31 gearing rite? would it be worth it 2 find a 5.4. is upgrading these motors cheap/ easy?
Old Aug 21, 2009 | 12:18 AM
429 boss mustang's Avatar
429 boss mustang
Well ill tell you 4.6 is a good motor just need to put money in it to do what you need to with it. It be cheaper and easier to just get a 5.4. That was my first choice but could find one so got a 4.6 but i love it now. Great little motor
Old Aug 21, 2009 | 07:03 AM
papajoemrt's Avatar
papajoemrt
I would go with the 5.4. By the time you purchase bolt on mod's and programmer for the 4.6 for minimal gains you will have spent more on the 4.6 than the 5.4. they are both good motors so i'd go with what is out there and go from there.
Old Aug 21, 2009 | 07:20 AM
Johnny Langton's Avatar
Johnny Langton
The 4.6L is a great small V8. It's reliable,fuel efficient,tows well if you keep it in the powerband,and will last forever with proper maintenance.
The best thing to do is gear it right if you're gonna tow with it. I used to run a 3.73 gear in my old '98 model, and towed a 30' travel trailer with a 6500lb GVWR all over the place. Never had a single issue with it. Just lock out OD,and go.
I got a look at it last weekend- that truck has 265K miles on it now, is running great, and my dad is still driving it all over the place.
JL
Old Aug 21, 2009 | 07:35 AM
thomastl's Avatar
thomastl
You don't indicate what size/weight trailer you are towing.
If you know your going to be towing - I would find a 5.4L. The torque is considerably more and at a lower RPM.
4.6L 290 @ 3250
5.4L 350 @ 2500
That is going to be a big difference in fuel economy and drivability towing a 5000 lb trailer.
There are plenty of good used trucks out there. Just keep looking. You will find the one you want at the price you want.
Old Aug 21, 2009 | 12:07 PM
fireball 440's Avatar
fireball 440
and to compare the 5.0 makes torque down low, the 4.6 makes it up high and not the best for towing heavy loads. I tow my 16' boat and a 2 place snowmobile trailer with no problems. Anything heavier than that I'd go 5.4.
Old Aug 21, 2009 | 12:53 PM
papajoemrt's Avatar
papajoemrt
gearing is critical if you plan on towing with a 4.6 or any motor for that matter. If you went with 5.4 you won't have the doubt in your mind. Then again if you want to pull anything without a doubt getta PS and consider it done.
Old Aug 22, 2009 | 10:53 AM
1979 Ford's Avatar
1979 Ford
I like my 4.6. It is a great engine. I have no problem towing... Keeping it in the power band goes a long way.
The 5.4 also is a good engine.
Old Aug 24, 2009 | 04:44 PM
gloorm's Avatar
gloorm
how well do these trucks burn rubber,this truck has 3.55 gears, what auto transmissions did they have?
Old Aug 25, 2009 | 09:14 PM
1979 Ford's Avatar
1979 Ford
Mine has the 3.55 gears and it will chirp the tires.
Old Aug 25, 2009 | 09:20 PM
Thudpucker's Avatar
Thudpucker
I towed a big Bass boat and a 20' Cargo trailer with household goods with my 4.6 and had no problem.
You can gear down a Mouse so he can pull a Freight train! You only pull the trailer once in awhile, go with the small 4.6. If your pulling the trailer every day, go with the 5.4.
The Transmission is going to be more of a problem than the engine choice.
