Best way to drop the rear of a dually ?
Old Aug 13, 2009 | 04:01 PM
Montano1's Avatar
Montano1
My 99 F350 CC DRW seems to sit awfully high. I'm wondering if there is a good way to drop it down 2 to 4 inches ? It reminds me of an old hot rod where the rear end was way up high with some fat tires on the back, and some skinny tires up front.
Old Aug 13, 2009 | 04:13 PM
strokersace's Avatar
strokersace
Is it a 2wd or a 4x4? If it's a 4wd, then you can just remove the 2" lift blocks in the rear to level it out. But then it would be as low as a 2wd.
Front end sag is pretty common on these pickups with 2 or 4wd. Most people would opt to raise or "level" the front end to compensate for it instead of lowering the rear.
Old Aug 13, 2009 | 04:17 PM
Montano1's Avatar
Montano1
It's a 2wd. If I raised the front to level it out I would need a ladder to get in !!
Old Aug 13, 2009 | 04:29 PM
strokersace
In that case you've have to do a spring hanger reversal kit where the springs would be under the axle. Or put it on air bags. but either way, you'll lose payload.
Do you not have running boards? I thought they were pretty easy to get in and out of a 2wd.
If you don't have any running boards, I've got a factory set of the molded black ones. Where do you live?
Old Aug 13, 2009 | 06:54 PM
Montano1's Avatar
Montano1
It had some hideous diamond plate running boards on it when I bought it, they came off 5 minutes after I got it home. I have been looking for some stock ones, but no luck yet. I live in Cali.
Old Aug 13, 2009 | 08:41 PM
BadDogPSD's Avatar
BadDogPSD
What size rear blocks do you have now? If 2" you can just take them out, if you have 4" and need 2", let me know as I have some!
Old Aug 13, 2009 | 10:26 PM
clux's Avatar
clux
About 4000 pounds should take care of it.
Old Aug 14, 2009 | 07:19 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
thats what i was gonna say! put a 10k lb trailer on the back!
Old Aug 14, 2009 | 10:54 AM
strokersace
The ones I have are stockers. Have the brackets but no bolts, but they aren't hard to get. I could wrap them up and send 'em your way if you wanted to work something out.
Being a 2wd, he shouldn't have any blocks in the back.
Old Aug 15, 2009 | 04:28 PM
Montano1's Avatar
Montano1
I guess I need to check for blocks. If I have them, can I take them out without any issues ?
Old Aug 15, 2009 | 04:59 PM
Montano1's Avatar
Montano1
Well no blocks, but I do have some purdy big air bags !!
Old Aug 15, 2009 | 05:21 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
doo whaaaat?
Old Aug 15, 2009 | 06:33 PM
Montano1's Avatar
Montano1
Originally Posted by PowerstrokeJunkie
doo whaaaat?
I measured from the ground to the bottom of my wheel well and it was 45". That was through the centerline of the axle, and it's almost 4 feet high !!
Old Aug 15, 2009 | 06:39 PM
61 uni's Avatar
61 uni
Try letting the air out
Old Aug 15, 2009 | 06:47 PM
Montano1's Avatar
Montano1
That's the first thing I did, they were empty.
