C6 no gears after warmed up
confident that I had the torque converter all the way in. Nearly
an inch behind the front of the bell housing, and the transmission mated right up to the motor with no problem. When I start up, the transmission went right into gear, no problem. Started down the driveway, and felt something bind up briefly. I stopped, and it clear up. Continued on, every thing seemed great, for about 500 yards, and then it went out of gear. Now every gear is like it's in neutral. What do you think, could it be the torque converter, or is the transmission finished.
08-Jul-01, 00:14 AM
I let the truck cool for a couple of hrs, and the transmission went right into gear. After it warmed up, the same problem occurred.
08-Jul-01, 02:50 PM
I read in one of my motor manuals that no drive in any gear
could be the valve body, or the pressure regulator? Where is
the regulator. Is it replaceable with the tranny in the truck, or is it internal meaning a tranny tear down to get to. Truck has all gears for about 5 minutes when started from cold, then looses all gears.
thanks
jeff
