00 exp front lls ??s
Old May 6, 2009 | 05:49 PM
SPRPRBGT's Avatar
SPRPRBGT
when my exp sits over night the rear lowers. is the front supposed to do the same? if so how much?
i lowered my truck useing the airride. now i realize i dont know how the front shocks are to be. meaning right now i dont think i have any air in them at all.....
Old May 7, 2009 | 03:30 PM
Omahastro1's Avatar
Omahastro1
I think but don't hold me to it thou, only the rear lowers. I beleive this is because the front end does have torsion bars on it plus the air shocks. The front shocks I think should have some air in them at all times. On 4x4's if you switch to 4lo the truck is suppose to lift 1" or two. It doesn't always work on mine.
Old May 7, 2009 | 03:35 PM
SPRPRBGT's Avatar
SPRPRBGT
i would love for the 4low air lift to work. mine did when i first got it but not recently.
do you have a stock eb?
id love to know a few measurements if you could help me
Old May 7, 2009 | 03:38 PM
SPRPRBGT's Avatar
SPRPRBGT
i need to know your front and rear ride height. threw the center of the rim from the fender well to the ground.
also if you could give a a distance of the bolt sticking out of the torsion bar mount. and also the length of the front shock. if possible.
thanks
Old May 8, 2009 | 08:17 AM
bucktaylor's Avatar
bucktaylor
Just checked my height with the Expy shut off, after sitting for 1/2 hour.
Fr. Driver 34 3/4" -- Fr. Pass. 34"
Rear Driver 34" -- Pass. Rear 33"
From a 2001 Expy. Eddie Bauer on 265/70R17 BFG Long Trail Tires, measured from ground to bottom edge of wheel well through the center of the tire.
Old May 8, 2009 | 10:28 AM
SPRPRBGT's Avatar
SPRPRBGT
thank you very much!
i just bought a 27' travel trailer and i want to have my exp in tip top shape to tow.
