one of my b3000 mirrors broke.
i looked at the replacement ones OEM and its 91 bucks!
so then i went to e-bay and found a pair of 01 ranger mirors with l.e.d. turning signals and wat not.
will i be good if i buy those for my b3000??
The two models are manufactured on the same assembly line. If the model year matches and they look like yours, they should fit. Most likely they would fit even across model years because the door skins stay the same for years.
I think there is a post here that describes the model years that are the same, such as the 1983-1987(9?) series, etc. Or you can check the advertisers here to see which fit your truck and compare that to the eBay listing. LMC ( LMC Truck Parts: Chevy Chevrolet Blazer S10 GMC Jimmy S15 Ford Bronco Ranger Pickup Pick Up Accessories/Catalogs ) carries a lot of parts specific to Ranger/B's
tom
