351W Issues when warm Rookie Shade Tree Mechanic
Almost every part has been replaced or rebuilt all parts are less then 30 days old. Including Engine Trans Carb Wires Plugs etc..
I added a link with pictures of the engine so you know what I am working with.
PS the wires where just zip tied for the pictures and now for operation the are away from eachother a heat.
<O
</O
1959 Ford F100 1969-1974 351W Crate Engine C6 Trans New Plugs Wires Filters Plugs gapped .42-.45 New Edelbrock Carb 1405 Manual Choke HEI Procomp Distributor vacuum hooked on passengers side other ports all plugged. New Gas Tank Lines Filter and Pump<O
</O
<O
</O
No Tachometer. Fire Order Used 1-3-7-2-6-5-4-8. Used passenger side as number 1 to install distributor 1-4 passenger’s side 5-8 drivers side front to back. Rotor was pointing at the number 1 when distributor was installed. Timed at 7 degrees.
<O
</O
<O
</O
Runs great at idle and around town. But today it cut off on me and I could not drive it home safe it would start again but run very rough shakes and sputters. Could I be 1 tooth off? Any help would be great. I am a US Army Soldier that normally shoots and fixes big 70 ton M1A1 Tanks. Thank you all very much in advance. Bill
http://www.flickr.com/photos/28697582@N04/<O
</O
