5.0 Mustang Shorty Headers and X Pipe
Old Apr 22, 2009 | 06:41 AM
73FOMO's Avatar
73FOMO
I posted this on the 73-79 forum but haven't gotten anyone that has tried....surely there are some guys on this forum that has?
Has anyone bolted up a set of Mustang Shorty headers and X Pipe to their 5.0 or 302 with a c4 or c6 transmission. I have the shorty headers on my '92 5.0 block in my '73 F100 and it looks like a set of Mustang X or H pipes would fit just like a normal mustang bolt up. I read on some of the Mustang forums of guys that had made the switch from t-5's to c4's and all said that is was an easy swap, but none mentioned any exhaust clearance issues around the transmission. I can pick up a pre-fabbed setup for reasonable $$$ and contemplating taking my chances on fit. I have cutting tools and welder if minor tweaking is needed. If it doesn't fit, cut and weld right?
Old Apr 22, 2009 | 09:56 AM
Conanski's Avatar
Conanski
Mustang exhaust parts usually present clearance problems in trucks, the frame, firewall, and front driveshaft and xfer case(on 4wd) get in the way.
Old Apr 22, 2009 | 10:52 AM
73FOMO's Avatar
73FOMO
It may, but it darn sure looks like it will work. Where the shortys fall on my '73 it looks like it will clear frame, firewall for sure...and I do not have 4wd. I think I am going to try, and if I have to cut and tweak that's fine, I was going to build my own custom anyway...was just trying to save a little work. Just wanted to see if anyone had already tried.
Old Apr 22, 2009 | 12:50 PM
MGT351's Avatar
MGT351
I think the main area you will have to work on is the trans crossmember. I have ran mustang shorties on a 70 F100 before without issue.
Old Apr 22, 2009 | 03:40 PM
73FOMO's Avatar
73FOMO
That's the only place where I could see a possible conflict....I think I can make it work without alot of fuss.
Old Apr 27, 2009 | 01:52 AM
Jrock909's Avatar
Jrock909
Hey 73, let me know if that H or X pipe works out, I would love to have that mustang sound on my truck with all the upgrades I have already done to my engine in my 92
Old Apr 27, 2009 | 06:34 AM
73FOMO's Avatar
73FOMO
Will do ... I am going to give it a shot. It may be a month or so, but I will let you know. I would like that same growl as well....but if this just works without a lot of mods I'll be a happy camper!
73FOMO
18
Oct 10, 2010 02:34 PM
1988fordf-150man
Exhaust Systems
Oct 15, 2004 05:14 PM
1993F150XL
Exhaust Systems
Sep 2, 2003 08:23 AM
