Shift lever not wanting to move out of park
Old Apr 13, 2009 | 10:54 AM
superduty4x4's Avatar
superduty4x4
Tried a search and wasn't finding much...
This is not my truck, but a co-workers. She says its hard to get it in and out of gear and I can't remember the fix for the life of me... doesn't it have something to do with tightening a couple of big Torx screws on the bottom of the column?
Old Apr 13, 2009 | 10:56 AM
RussB's Avatar
RussB
You got me buddy ! Might want to have a look at the linkage under the truck ! There's a little plastic thinginy down there that might be broken !
Old Apr 13, 2009 | 10:59 AM
superduty4x4
I'm going to offer to look it over for her so she doesn't have to take it to a mechanic, I'll be sure to check the linkage too. Thanks Russ.
Old Apr 13, 2009 | 11:15 AM
jasonch's Avatar
jasonch
i think that lil plastic thing is yellow, with small notches in it, can remeber right now though
Old Apr 13, 2009 | 11:27 AM
RussB's Avatar
RussB
Mine is white ! Its where the cable comes down and meets up with the trans..
and yes.. it does have little notches in it so you can adjust it ! You may be able to change its position at that end so she can change gears properly ! The cable may have stretched enough to make it come out of adjustment ! Be the good guy Chase and go fix the girls truck ! I just did the same thing on friday ! Changed her brake pads.. oil.. rotated her tires.. and then she took me out for dinner !!!!!!
Old Apr 13, 2009 | 11:30 AM
jasonch's Avatar
jasonch
there ya go, i cant remember which way to move it though, i think torwards the front of the truck????
Old Apr 13, 2009 | 11:32 AM
RussB's Avatar
RussB
Ya I can't remember either ! You'll have to do the old trial and error deal !
Old Apr 13, 2009 | 11:34 AM
superduty4x4
I'll have to poke around and see what I can see, thanks again Russ.
Old Apr 13, 2009 | 11:45 AM
PaysonPSD's Avatar
PaysonPSD
If she is parking on a slope and not setting the e-brake first it is hard to get out of Park. Just a thought.
Old Apr 13, 2009 | 11:52 AM
superduty4x4
I'll keep that in mind Robin.
Old Apr 13, 2009 | 12:58 PM
superduty4x4
Problem appears to be in the column- how hard is it to get to the torx screws that tend to come loose? She ran the truck down to the mechanic to have them give their assessment of what is needed, but I'm determined not to let her spend any $ at the shop if I can help it.
Old Apr 13, 2009 | 01:00 PM
SUPERDUTY OUTLAW's Avatar
SUPERDUTY OUTLAW
might also check (I think) fuse 15 for the brake shift lock thingy. Cant think of the right word but it locks the shifter in park unless the brake is applied and if it is blown it won't work. just a suggestion. 2nd row of fuses 4th one down.
Old Apr 13, 2009 | 01:13 PM
superduty4x4
It moves, just not the way it should.
Old Apr 13, 2009 | 01:24 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Good of you to help her Chase. Just watch where you go poking around.
jasonch's Avatar
jasonch
well let me know how it works out, mine has got lots of slop in it, and i dont want it there any more.
