Help with a cam choice
Old Mar 4, 2009 | 02:03 PM
Zero Obliquity's Avatar
Zero Obliquity
I have a 88 F150 with a 302 and the 5 speed. The motor needs to be rebuilt. I would like to upgrade the cam while I have the motor out, but am not sure on the best bet. The truck has 31” tires, 3:08 (18 code) gears and long tube headers. I have a set of 4:10s I could put in but would not want to kill my MPG because I drive the truck for work. What is the best cam for my truck? Thanks
Old Mar 4, 2009 | 02:11 PM
lew52's Avatar
lew52
With 31in back tires the 410s would help you out a ton over the 308s... I would thik that would even get better milage?? mabee im wrong ?? I like the e 303 cam...There will be a lot of help shortley with cam advise ..Lew
Old Mar 4, 2009 | 02:15 PM
1966Tbird's Avatar
1966Tbird
yeah you would definatly use the 4.10s you will get better mileage with a 302 and 4.10s with 31s than 3.08s
as for the cam the E 303 sounds NASTY
here is the cam i used and i LOVE it couldn't be more happy with it but i doubt it will work with fuel injection unless you have mass air it's a speedpro cam the # is listed under the info box on youtube i forget what it is
YouTube - Cammed out 5.0 mud truck open headers
Old Mar 4, 2009 | 08:21 PM
Zero Obliquity
The cam has got to work with the Speed Density. I am not sure how much you can tinker with the SD.
Old Mar 4, 2009 | 08:28 PM
Conanski's Avatar
Conanski
Yes.. use the 4.10s and look at the Comp 31-255-5 flat tappet. If you are going to convert the motor to use a roller cam there are a lot more cam choices.
Old Mar 4, 2009 | 08:31 PM
Sooper-Doodie's Avatar
Sooper-Doodie
I would get the computer from a 5.0L mustang and wire in a MAF while you are at it. Since you have a manual trans, it makes things easier. Last MAF swap I did, I used a A3M computer. Worked quite well.
Old Mar 4, 2009 | 09:01 PM
nnewman's Avatar
nnewman
I've got the 31-255-5 cam that Conanski mentioned. It's running with speed density with no drivability problems. I like the cam; there's no big-cam lope, but a truck doesn't need that. I've never checked the fuel mileage with the new cam, but it seems to be pretty well the same as the stock engine.
Old Mar 5, 2009 | 05:01 AM
Zero Obliquity
Thanks for all the help. I will give the 31-255-5 a try. I would have thought the 4:10 would make my MPG worse.
Thanks again
