4.9trans to a 5.0
Old Mar 4, 2009 | 10:23 AM
f150guy88's Avatar
f150guy88
4.9trans to a 5.0
i,ve got a 95 f-150 and a 88 f-250 with a shot trannsmission both are standard and i was wondering of the 95 trans will bolt up to the 88 motor and if i will have to swap transfer cases,
Old Mar 4, 2009 | 10:29 AM
rockin300's Avatar
rockin300
im not sure,but ill say no, im sure someone will correct me if im wrong on this
Old Mar 4, 2009 | 10:35 AM
f150guy88's Avatar
f150guy88
the question is does my(88 f250 4x4 8 lug 5.0) have the MAZDA M5R2 trans or the GERMAN S542
Old Mar 4, 2009 | 10:44 AM
rockin300's Avatar
rockin300
i think its the mazda m5r2
Old Mar 4, 2009 | 10:52 AM
Dean88's Avatar
Dean88
The answer is yes the 300, 302, and 351W all have the same bellhousing pattern. And the 88 should have the ZF-5 but I'm not sure which model yours should have, that part really doesn't matter cuz all of the ZF-5's have same housing.
You may have to swap the driveshaft from the 95 to the 88, but I don't think so.
Old Mar 4, 2009 | 12:53 PM
rockin300's Avatar
rockin300
i just learned something new
Old Mar 4, 2009 | 09:03 PM
Dean88's Avatar
Dean88
Another thing I just though of, I think the ZF 5 has an external slave cylinder, and I know the M5OD has an internal slave cylinder.
But the swap will work but you may have to swap a few tid bits of pieces from the donor truck to your 88.
But one slight problem is the M5OD is much weaker than the ZF5, so be weary of heavy hauling or pulling.
