Drive Shaft/Slip Yoke Removal
Old Feb 20, 2009 | 12:07 PM
bassaway's Avatar
bassaway
I have started to feel the "thump" during initial acceleraton in my 2007 F-150, which appears to be due to slip yoke. I bought the special ford grease and my next obstacle is figuring out how exactly I get the slip yoke out. Ive read numerous theads and TSBs regarding this issue which only reference Section 205-01 of the F-150 Workshop Manual for drive shaft removal instructions. Could anyone give me some insight on a correct procedure. It appears I should begin by dropping the drive shaft first by removing the pins at the U-joints (index marking, of course), but I would prefer knowing a approved/successful method before diving right in. Thanks!
Old Feb 20, 2009 | 12:24 PM
FX4Jim3's Avatar
FX4Jim3
Mark it, unbolt it, and slide it out.
Old Feb 20, 2009 | 12:39 PM
jay-rod427's Avatar
jay-rod427
Couldn't be said much simpler. be sure to put plenty of the grease on the yoke when you reinstall it, any excess will squeeze back out anyway.
Old Feb 20, 2009 | 02:12 PM
bassaway's Avatar
bassaway
Thanks for the fast replies. Still just slightly confused though...
There are no bolts on the slip yoke side of the drive shaft (next to the center bearing), just a U-joint with clip pins. However, there are bolts on the rear-end gear side of the drive shaft. Are those the bolts you are referring to? I just remove those bolts, drop the shaft, and pull the shaft out the slip yoke? Thanks again.
Old Feb 21, 2009 | 07:05 AM
FX4Jim3's Avatar
FX4Jim3
Thats it. unbolt the c-clips drop (lower) the shaft and slide it out.
woodsmoke
Dec 29, 2016 06:12 AM
woodsmoke
Dec 28, 2016 04:13 PM
74Mav
Jun 18, 2016 05:10 PM
Colorado Highboy
Mar 21, 2016 03:13 PM
