need help
Old Feb 19, 2009 | 10:11 PM
royslsbry's Avatar
royslsbry
need help
i have 2000 f350 the turbo isnt working no power where should i start
Old Feb 19, 2009 | 10:13 PM
JT250's Avatar
JT250
how do you know the turbo isnt working? Have you taken the intake hose off and looked at your compressor wheel??
Old Feb 19, 2009 | 10:18 PM
royslsbry's Avatar
royslsbry
i dont hear it anymore and have lost power just happened havent examined yet
Old Feb 19, 2009 | 10:24 PM
JT250's Avatar
JT250
Just start by taking the intake off and examine the wheel. Look for big nicks or pieces. Then try to move it side to side. You shouldnt be able to make it contact any of the surrounding metal. It could also be something else causing you not to have any power and that would result in not hearing the turbo. IE one or more cylindars not working. Hopefully if there is something wrong it is the turbo. That would be the easiest fix.
Old Feb 19, 2009 | 10:29 PM
rbaker6336's Avatar
rbaker6336
did an intercooler hose blow off?
Guess I should ask if the problem came on gradual or all of a sudden
Old Feb 19, 2009 | 10:33 PM
royslsbry's Avatar
royslsbry
all of a sudden no hoses blown off truck runs fine no smoke
Old Feb 19, 2009 | 10:39 PM
JT250's Avatar
JT250
What do you mean by "truck runs fine". Its okay now or it idles but cant rev it up?
Old Feb 19, 2009 | 10:46 PM
royslsbry's Avatar
royslsbry
it idles fines and revs up
Old Feb 20, 2009 | 07:07 AM
F350-6's Avatar
F350-6
Inspect the wheel for play, a little side to side is ok, any in and out movement is bad. Also check your up pipes for leaks. They can rob boost power.
How many miles are on the truck? Any modifications over stock to the truck? I'm guessing you don't have a boost gauge to monitor boost readings.
Old Feb 20, 2009 | 08:00 AM
Ponyboychris's Avatar
Ponyboychris
We need a bit more in-depth description of the "no power" statement. Does the truck not accelerate? does it loose power at a certain RPM? We love to help but need more info.
Old Feb 20, 2009 | 08:09 AM
Action4478's Avatar
Action4478
Try unplugging the map sensor for a test .... (the wireing plug)
