Is there a link on here for tightening my steering?
Old Jan 20, 2009 | 06:07 AM
erinaldi's Avatar
erinaldi
The truck is coming along. I'm making good progress making these minor repairs and now am interested in some of the fine tuning. I replaced the original steering box in my 55 F100 with a F600. Same set-up but a lot beefier. Steers much easier. But as before, I have about 3-4" play. I read once where there are gaskets or shims I can add. Any help?
Old Jan 20, 2009 | 06:18 AM
Fomoko1's Avatar
Fomoko1
A post on this from mtflat:
https://www.ford-trucks.com/forums/s...66&postcount=3
Old Jan 20, 2009 | 02:26 PM
Pappys53's Avatar
Pappys53
Does the F600 steering box bolt in or did you have to custom fit it? Is it one piece like the f100 and how much easier does it steer than the f100?
Old Jan 20, 2009 | 02:54 PM
9teen56f100's Avatar
9teen56f100
Are you sure the play is in the steering box? On my panel most of the slop was in the drag link/ pitman arm. rebuilt drag link and replaced the pitman arm, all is good again.
brian...
Old Jan 20, 2009 | 07:34 PM
Julies Cool F1's Avatar
Julies Cool F1
brian...
I saw someone is selling replacement pitman arm *****! I don't remember who, but if anyone needs to know, I'll search for them.
The procedure for tightening up the steering gear lash is also in the owners manual maintenance section.
It's simple: Loosen the locking nut, turn the adjusting screw in until it contacts, then back 1/8 turn. Check to see if it rubs and if so back it off a little more. Then tighten the locking nut!
Also, check you tie rod ends.
J!
LoneStarTrucker
May 9, 2008 06:08 PM
steve340
Nov 22, 2006 11:21 PM
Fordman79
Jul 3, 2006 03:05 PM
moonley
24
Apr 8, 2005 12:35 PM
