What problems sould I look for on a 2002 exp xlt 5.4 150,000 miles?
Old Jan 12, 2009 | 09:04 PM
stu02expy's Avatar
stu02expy
Going to test drive it tomorrow. Any real problems with these vehicles? Anybody think the high miles is an issue given its an 02? From what I understand the 5.4 is a great engine.
Old Jan 13, 2009 | 05:36 AM
robbizkit's Avatar
robbizkit
If it has the moonroof be prepared for water leaks.
Old Jan 13, 2009 | 09:20 AM
Frat-man-du's Avatar
Frat-man-du
make sure the 4x4 system has had regular maintenance!
Old Jan 13, 2009 | 09:46 AM
SBastow's Avatar
SBastow
ball joints, tie rod ends, blend door, odom blackout
Old Jan 13, 2009 | 04:46 PM
MOOK929RR's Avatar
MOOK929RR
that is pretty much the rig i have and i would make sure its not running the original:
battery
alternator
belts
ball joints(top and bottom) and tie rod ends
tire wear (make sure its even)
check for odom blackout
check bottoms of doors for rust
moonroof shouldnt leak if drip bar is in place, and drains are cleaned out
records of plug change and other regular maint...
that 5.4 will go to 300k miles if you take care of it....
