Navi Energy Susp Bushing question
I want to now if anyone had changed the rear end links bushings on a LLS 99 Navigator with Energy suspension bushings and the rear track arm bushings.
The Rear sway package comes with 8 halfs bushings, 4 inner sleeves, 2 bolts and nuts and 4 flats washers, plus the sway bar bushings.
My questions are:
How can i loose the old bushings without the outer sleeve?
Is the bolts provided used for attach the end link to the sway bar on the bottom part of the system?
How i should use the 4 flat washers? On the exterior part of the Bushing (between the bolts heads and the bushings).
Any help or tip will be appreciated.
Thanks, and happy new year.
