Smelling Anti Freeze, But No Sign of Leak
Old Jan 8, 2009 | 07:23 PM
scottspoerry's Avatar
scottspoerry
On my 99 XLT 4.6 I have been smelling the unmistakable scent of anti-freeze, but I see no sign of leaking underneath the vehicle. It looks like the reservoir level may have dropped slightly, but I don't see signs of leaks near any hoses.
No change in guages or dash lights.
I smell it with the window down and I don't remember picking this up during previous seasons. I don't think the smell is coming from inside the vehicle.
Any thoughts?
Old Jan 8, 2009 | 08:36 PM
3rd car's Avatar
3rd car
maybe ur burning a little
Old Jan 8, 2009 | 08:50 PM
TerryB99's Avatar
TerryB99
Any thoughts?
Well, I may have some bad news for you. I too, noticed a bit a coolant smell from time to time the last few months. No other symptoms, except recently, my coolant recovery bottle was empty.
https://www.ford-trucks.com/forums/8...tle-empty.html
Ford is in the process of tearing my engine down now to find out where it is going.
Old Jan 8, 2009 | 09:02 PM
Sparky83's Avatar
Sparky83
i would check your exhaust mate and see if its colored... or if its smells sweet... if it smells sweet then your definitely burning it...i forget if its blue or white... but i think blue is oil and whites antifreeze... and black would be running really rich...
Old Jan 9, 2009 | 07:07 AM
wom's Avatar
wom
most likely head gasket a they are prone to be go to top this page the recall/ tsb's go to full text look up for excursion or f150 head gskets tsb 03-5-2 ? this manufacurtring machineing chips are wreking havoc on causing gasket failures not just on oil leaks but coolant loss also
Old Jan 9, 2009 | 06:33 PM
scottspoerry
I am not smelling anything in the exhaust, but it does seem like it could be the gasket. It was repaired under warrant about 100,000 miles ago.
Old Jan 26, 2009 | 02:52 PM
scottspoerry
I have narrowed down the location of the odor. It blows out from under the left front wheel well.
I still can't see any actual leakage and I don't see anything that looks like it may be a gasket leak. After refilling the reservoir, I cannot see any appreciable change in the coolant level after about 500 miles of driving....250 on one trip.
Old Jan 26, 2009 | 03:25 PM
alloro's Avatar
alloro
Could've sprung a small leak in the radiator core. The airflow from the fan would keep it from puddling and giving away it's location. The airflow would also carry the odor back and out the wheel well and other places on that side.
Old Jan 26, 2009 | 03:36 PM
scottspoerry
A small leak in radiator core makes sense. It's got 170k on it. I am thinking I can just ignore it and drive it ionto the ground, but I wonder if a pressure test is in order just to make sure.
Old Jan 26, 2009 | 03:41 PM
alloro's Avatar
alloro
Since you're smelling AF you already know you have a leak, so a pressure test isn't going to tell you anything you already don't know.
Old Jan 26, 2009 | 03:47 PM
scottspoerry
So true. I am going on a drive out to Utah and back in February and since it doesn't overheat, it doesn't smell inside the cab, and whatever is leaking is negligible, I think it will just go for it. If it blows up, they can bury it wherever it dies.
Old Jan 26, 2009 | 04:35 PM
alloro's Avatar
alloro
You could alway replace the radiator and save yourself the potential aggravation of towing costs and getting stranded.
Old Jan 26, 2009 | 06:58 PM
Freak4Ford's Avatar
Freak4Ford
Have you checked your heater hoses? With 170K on your truck they probably need replacement.
Old Feb 1, 2009 | 12:29 PM
scottspoerry
I did check the hoses...no sign of leakage there.
I had the system flushed and for some reason I am not getting nearly as much smell.
Old Feb 2, 2009 | 02:25 AM
c_hohensee's Avatar
c_hohensee
I went through the same issue of smelling af but not seeing it. As I have the 5.4 I lost the number 4 cop due to the leak at that heater hose connection on the right rear above the motor. At least with the 4.6 you do not have cops, but you stiil might have that hose connection.
