NEED HELP!!! I broke the EPS off in the damn bracket!!
Ok, so I wanted to change the tube that was getting corroded and clean out the Exhaust Pressure Sensor because I was getting a code and it was running a bit crappy. Well, I follwed Guzzles directions and used a deepwell 1" socket to take off the sensor. Unfortunately it just snapped right the hell off. So now I had to get another sensor from the dealer ($153) and I still gotta take the piece out of the bracket it's in. I tried to use an easy-out, but the damn bracket is just twisting. I think it't the same piece that is the HPOP gear cover?
So anyone got any ideas where I can go from here? Can I take the cover off without oil gushing all over the driveway? It's only held on with 2 bolts. I can't get a drill in there......
HELP!!
HELP!!
You can take the bracket off without oil pouring out. I took mine off when I did my EBPS. The nipple that the tube attaches to on the underside was galled and I had to chase it. I too was apprehensive about removing it but had to in order to make the repair to the threads. Take it off and don't sweat it . There's a little gear behind it, no oil.
Well I got it all done about an hour ago. I took off the plate, drilled and tapped the fitting, applied a bead of black RTV and stuck it back on. Although the new tube was bent different, it went on no problem, as I started the bottom first.
I also swapped out my spare black CPS for the stupid grey one, which will now be my spare until I get another black one. Of course I didn't wear my gloves, so as I busted the CPS bolt loose I proceeded to rip off a 1"x.25" patch of skin from my right hand hehe.
Thanks again for ya'lls help- I tried to rep everyone, but the rep police said pass some more around first...
