Glow plug control switch
The Glow Plug Relay is looking for a ground from the PCM to light the glow plugs. If you remove the wire that comes from the PCM on the GPR (insulate it), you can then run a wire to a momentary switch and on to ground to have manual activation.
In warm climates, this is a very good idea, as we virtually don't need glow plugs where I live (at least MOST of the year)!
I wrote something about this a little over three years ago:
https://www.ford-trucks.com/forums/4...ml#post3102511
Pop
Pop
I installed an LED on mine and also a manual switch. A switch on the dash to control the coil between 85 and 86, and a fused hot wire to 87 and a lead from 30 to the control B+ pole of the GPR.
This setup is the best of both worlds in my opinion. It allows me to turn the GP's on without the key in the ignition, but the PCM will still shut them off after the 2 minute or so cycle (even with no key in) to keep me from accidentally running the plugs too long.
I can't tell you the "why" the PCM can still control off-time without looking at a diagram- I can tomorrow if you like. To get full manual control, you must remove and isolate the factory B+ control wire to the GPR coil.
Pop
Manual control of the glow plugs offers you the benefits of running the glow plugs for a longer period in REALLY cold weather, and not having them AT ALL when it's the middle of the summer and a hundred degrees out.
Think of all the battery current you'll save from being used. WIthout the GPs running, the starter will have both batteries all to itself, and the truck may even start quicker!
Pop
Pop
