36 Ford Pickup i Might buy
Old Jul 6, 2008 | 03:01 PM
mossyoak1992's Avatar
mossyoak1992
well me and my grandpop just saw this 36 sitting buy two barns the truck was never there before i even looked on goggle earth to check so we stoped and went over and looked at it and found out how good of condition its in there is no rust all the way through that we saw it does have torn and repaired left fender i forgot to look at right it appears to be a 1 ton maybe 1 1/2 ton not sure it is a short wheelbase truck though i will be on here looking for info on the truck like what size tires did it come with factory and how can it tell besides the vin the size of the truck i havent talked to the owner yet but i am set on buying this truck i hope they will let it go i will let you guys know if i get it
Old Jul 6, 2008 | 05:14 PM
mossyoak1992
Heres A Picture I Just Took
Old Jul 6, 2008 | 07:56 PM
47Ford - 1.5Ton's Avatar
47Ford - 1.5Ton
Old Jul 6, 2008 | 07:57 PM
47Ford - 1.5Ton
Ford 1-1/2 Ton, 138" wheelbase, 5 lug, 22.5 Wheels..... by ballpark, I doubt its the 158" verison..... look more into it...get the vin and go from there to be sure though.
~Mike
1947 Ford 1.5 Ton DRW
Cummins 3.9L Turbo Diesel
ZF-S542 5 Speed OD manual (Out of a 96' Ford F-350)
Old Jul 7, 2008 | 09:22 AM
mossyoak1992
i walked over and looked at it and it did have a short whellbase when i look again ill measure it
Old Jul 7, 2008 | 09:23 AM
mossyoak1992
~Mike
22.5" wheels i have been reading on this site i thought it should have 20" wheels
Old Jul 14, 2008 | 12:54 PM
mossyoak1992
dang not to many people on this forum is there on another forum im on there are like 1000 posts a day well i have another question what would it invole to convert to juice brakes also i think i saw pics of the master cylinder under the cab is this how you can do it because i dont want the master cyl. on the firewall oh also i dont want to swap axles in the rear so does this mean i have to stick with mechanical brakes
Old Jul 15, 2008 | 10:38 AM
47Ford - 1.5Ton
What other forum are you on that gets that many posts a day? (Sorry, I need some help on my 47 too.)
Old Jul 15, 2008 | 03:12 PM
mossyoak1992
its not an old truck forum its a ford ranger forum
Old Jul 16, 2008 | 09:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There is no VIN number on this truck. VIN's were not used prior to 1948.
The truck is registered by the engine number aka the serial number, but don't be surprised if it doesn't match what's on the registration.
If the engine was replaced by a Ford dealer, they would stamp the original number on the replacement engine, but if the engine was swapped by a previous owner, the numbers won't match.
Look for the engine/serial number on the "hogshead" (clutch housing) and on the engine block.
Some serial numbers were also stamped on the frame, adjacent to the steering gear box.
Old Jul 17, 2008 | 02:54 PM
mossyoak1992
well i am pretty sure its the original motor because its only got 11 thousand on the clock if not it is the correct motor
Old Jul 17, 2008 | 04:33 PM
3Mike6's Avatar
3Mike6
Unsure on your larger truck...but...
There is no info on the engine that will help you figure year, ND mentioned "clutch housing", but I'm pretty sure he's confused that with the tranny case itself...Ford didn't stamp the flatheads, figuring (general consensus) that the engine would be changed, but the tranny would live on.
Now if it were a 1/2 ton (again, not sure on thelarger trucks) you should have a sn stamped behin) the steering box (on top side of frame) and another on the top rear driverside frame rail.
You have either a '35 or a '36, I'd have to look at the side shot of the grill and also the hood sides to verify the year...the '35 grill is "shorter"-from where it touches the hood sided to the front of the grill, and the "V8" logo on a 35 is in the center of the louvers, and the '26 is towards the front of the louvers...(oly way I can tell'em apart).
Old Jul 18, 2008 | 01:41 PM
mossyoak1992
i already know its a 36 but thanks for the info any way i read somewhere else about what you said so thats how i figured it out
Old Jul 19, 2008 | 12:55 PM
mossyoak1992
well the guy wont sell the truck he says its an old family truck and he is goning to get it restored (hes really rich so i kind of figured he would get it restored for his newly opened vineyard)
46yblock
1947 and Older Ford Trucks
Jun 27, 2011 11:06 PM
fishforlife2007
Offroad & 4x4
Apr 10, 2010 10:43 AM
RogueSpear2023
General Automotive Discussion
33
Aug 25, 2007 04:26 PM
Joe Tx
Offroad & 4x4
Aug 8, 2007 05:36 PM
muffdr
Jun 2, 2004 03:53 PM
