Blue Oval On Grille Discolored
Old Jun 14, 2008 | 07:24 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
my 06 Lariat has a gold honeycomb grille with the FORD blue oval in the middle which has become very discolored. Is this a warranty item and would they be able to change just the emblem or am I looking at a new grille? How much?
Old Jun 14, 2008 | 10:02 PM
Warbird Mechanic's Avatar
Warbird Mechanic
The good news is that the blue oval emblem on the honeycomb grille is removable. Its secured to the grille by two twisty-type half-nuts on plastic studs on the backside of the grille, in which these plastic studs are attached directly to the blue oval emblem itself. My F-150 truck has the same type grille only its all black. Not sure if these emblems are covered by the warranty or not, nor do I know how much they cost. I would suggest calling your local Ford dealership and ask them if the emblem is covered by the warranty before you remove it yourself. If you decide to remove the emblem yourself, be sure to save those half nuts and take great care in installing these nuts onto the new emblem's studs or else you may snap off those plastic studs if the nuts are torqued too tight. Been there, done that and had to buy a customer another new Chevy emblem as a result when I worked as a Chevy tech at a Chevy dealership 3 years ago. The Ford oval grille emblems are attached the same way unfortunately. Hope this helps!
Jim
Old Jun 15, 2008 | 07:44 AM
firedog550's Avatar
firedog550
Mine is doing the same thing and IT going to the dealer in the morning for that and some other minor issues. Dealer here said they were going to replace it.
Old Jun 15, 2008 | 03:57 PM
Big-Red-Lariat
the blue on mine looks bubbly like the cheap stick-on window tint; after a few months you see air bubbles and it is an inconsistent color; same problem?
Old Jun 15, 2008 | 04:20 PM
crabhab's Avatar
crabhab
The front grill emblem is made in Italy (have no idea if that has anything to do with it) Did the same on my 2006 superduty. Search around here for the part number if you are out of warranty it can be expensive if not ordered form an online ford dealer parts dept.
Old Jun 15, 2008 | 06:59 PM
firedog550's Avatar
firedog550
Mine looks like water has got inside of it. A co-worker/ friend of mine had the same problem and dealer replaced it as well under warranty
Old Jun 17, 2008 | 12:31 AM
wildcat99's Avatar
wildcat99
Had both front and rear ovals replaced at the dealer under warranty. They were peeling the same as yours. The front looks like the easier one to replace.
If out of warranty, check out tascafordparts.com or other site sponsors here. I think Tasca is one, but I can't find them listed at the moment. The front goes for about $20 and the rear $32.
Old Jun 17, 2008 | 06:13 AM
firedog550's Avatar
firedog550
Mine was replaced under warranty yesterday
Old Jul 29, 2008 | 04:06 PM
Rod Jr.'s Avatar
Rod Jr.
How to remove?
I have a new front emblem for my 2006 Superduty but still can't figure out how to remove, I removed the top rubber cover to access radiator and removed one and only jam nut, but still no go.
Old Jul 29, 2008 | 05:42 PM
Big-Red-Lariat
mine was glued + 2 speed nuts on back. Dealer did it under warranty. Goodluck.
Old Jul 29, 2008 | 06:33 PM
Frd67cobra's Avatar
Frd67cobra
Had to order one when my new grille came without the emblem. Word of caution when ordering one.... make sure you specify the one you need has the two mounting studs/nuts on the back. Ford carries another one that has only the 3M tape on the back, once its on you won't be able to remove and re-use it, it'll either bend or break, and won't re-stick. They sent me the wrong one first, had to return it and wait for the correct one.
Old Jul 29, 2008 | 08:09 PM
Rod Jr.'s Avatar
Rod Jr.
My '06 only has 1 mounting screw in the middle, is it glued on?
Old Jul 29, 2008 | 09:25 PM
Frd67cobra's Avatar
Frd67cobra
Are you sure it's a mounting screw and not just a locating stud? The taped ones have a center mounted locating stud that fits through the grille to position the emblem correctly because the tape grabs firmly and can't be repositioned once it's pressed on. Apparently Ford uses both types, my '06 has the two mounting screws.
Old Jul 30, 2008 | 12:21 AM
Rod Jr.'s Avatar
Rod Jr.
The center has only one plastic piece with a 10mm jam nut on it.
Old Jul 30, 2008 | 05:32 PM
Frd67cobra's Avatar
Frd67cobra
Back off the nut and see if the emblem pops out, if not, it's got the tape also.
