any one in sacramento area that knows this carb stuff?
my 66 has a 90's roller 302 in it (yes i veriffied that it has a steel gear on the dizzy) and a 600cfm(?) holley. the holley took a crap on me, and we adjusted everything we knew to adjust. i bought a new 600 cfm holley and now i just don't know how(and am not comfertable) adjusting it my self. i was able to adjust the idle up enough for it to keep running while in drive. but i need it adjusted properly.
i miss my 65 that started every time i turned the key(no help from the peddle needed) and ran like a raped ape!
is there any sac area folks that could give me a hand(and possiblly show me the non fuel injected side?)?
Get a vac guage on it, if your mixture is that far off ok, but my guess is you got a loose vac line somewhere. (Base of the carb, brake line, other lines, back of the intake.. start looking if the gauge tells it to be the case.)
thanks, i'll check it out. shuoldn't be too hard, there is only 2 vac lines. one to the vac advance and one to the trannie.
