Rear Liftgate Noise
Old Apr 23, 2008 | 09:28 PM
builtfordtough13's Avatar
builtfordtough13
Rear Liftgate Noise
Is it common for Expy's to have a lot of noise coming from the back of the vehicle, kind of sounds to me like its coming from the rear lifegate. Is there anyways to fix the noise, or is it just normal.
Old Apr 23, 2008 | 10:06 PM
sbclemens's Avatar
sbclemens
Is there something rattling around in the jack stand compartment?
Old Apr 23, 2008 | 10:22 PM
alloro's Avatar
alloro
Did you try adjusting the latch to make the hatch shut a bit tighter?
Old Apr 25, 2008 | 02:03 PM
Frat-man-du's Avatar
Frat-man-du
Funny I just noticed this on my '03. At first I though it was the dreaded rear blend door, but after pushing on the gate a few times I could replicate the noise.
I adjusted the little hexigon bumbers out but it made no difference. I have not had a chance to try anything else. I might put new foam bumpers on the rear glass to see if that helps..
Old Apr 25, 2008 | 02:25 PM
alloro's Avatar
alloro
Adjusting the rubber bumpers won't help, move them back. Those are there just to take some of the shock when the gate is slammed shut. You have to adjust the latch catch piece at the bottom center of the hatch opening. Loosen the tork screws and slide the catch forward 1/8" at a time, retighten the tork screws, close the hatch and push on it, feeling for movement. If it's still loose, adjust it in another 1/8" until it's nice and snug. All of the doors can be adjusted for wear and flattened weather stripping this way. With the side doors you have to be careful not to adjust the catch up or down. If it's too high you'll strain the latch, if it's too low you'll strain the hinges.
Old Apr 25, 2008 | 02:38 PM
Frat-man-du
Thanks, I will try that this weekend - makes sense my wife just brought home a dresser and had hard time slamm'n the door. Bet it moved that latch.
johnstonmatt77
Nov 17, 2015 02:19 PM
Vin Diseal
Aug 25, 2015 04:48 PM
KGator
Jul 11, 2012 03:08 PM
DVigeant
Dec 11, 2003 04:52 PM
