TIMING ON 351W 1996 BRONCO
Old May 19, 2002 | 10:39 PM
adam351wbronco's Avatar
adam351wbronco
WHAT IS THE BEST TIMING ON THIS ENGINE
10*BTDC 13*ATDC
WHAT THE BEST SETTING FOR POWER AND TORQUE
Old May 21, 2002 | 07:45 PM
mu5tanggt's Avatar
mu5tanggt
Stock timing is 10 degrees BTDC, best way to find optimum is to bump up timing in 2 degree increments and road test, once it starts to ping under load back it off 2 degrees and enjoy. you may need to go to premium to get the best acceleration without pinging.
Old May 21, 2002 | 10:33 PM
TorqueKing's Avatar
TorqueKing
Yeah, I like to just loosen the distributor clamp up a little, so it will hold it down effectively, but you can rotate it by hand to make adjustments. Then you set, rev it up, feel it a littel, and adjust. One thing to monitor is the idle speed, the faster it idles, the better the timing is. Just don't get your hand chopped off in the fan, it's kinda tricky reaching it with the fan running.
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old May 22, 2002 | 07:12 AM
71swissaqua's Avatar
71swissaqua
Franklin2
Jun 2, 2019 07:12 PM
jake_c_19
Jul 5, 2015 03:19 PM
429 merc
21
Jun 30, 2015 06:37 PM
351Cleveland C4
17
Sep 1, 2014 11:33 PM
351Cleveland C4
Jun 1, 2014 08:03 PM
