Major miss under load after a manifold replacement.
I've tried everything i can think of to solve this problem. Computer checks out ok in both the KOEO and KOER tests. fuel pressure is 50psi with key on and running, and stays steady while driving. I replaced all 6 spark plugs and wires, the cap and the rotor. I used a can of starter fluid and a can of carb cleaner trying to detect manifold leaks. I also checked the vacuum lines, and replaced a few that seemed worn.
A vacuum test shows good vacuum at idle but drops way down under a load. Someone at an auto parts store told me this was normal, but I'm no sure. If i do have a manifold leak, its seems only to leak under a load and that does not seem to make any sense.
The van ran very well before this botched repair, so i don't think my problem is compression or what have you.
I also swapped out the egr valve with a spare, no change. I disconnected the exhaust manifold at the pipe to see if the converter was plugged, no change. I pulled all the spark plugs after a few hundred miles like this, trying to find the missing cylinder(s), all looked clean and good.
Anyone ever had this problem? I'm considering a stick for the gas pedal and a very tall cliff.
How segnificant is the drop under load? If anything during acceleration vacuum should increase as velocity through the manafold increases not drop. Again, this suggests you've got a vacuum leak.
Since you replace the lower intake double check all vacuum lines and specificly test around all intake mating surfaces. The poor performance, lower fuel pressure and odd vacuum drop under load strongly suggesting that your sucking extra air in someplace downstream of the plenum chamber. I'm a little suprised that your not getting a too lean error from the computer.
If your fuel pressure stays at 50psi while driving that is probably your problem. It should rise to 55-60 under load. The increase in fuel pressure is like the accelerator pump and powervavle on a carb all rolled into one. Without that it will run lean.
