Idle Vacuum Valve Part number
Old Jul 12, 2001 | 12:04 PM
fordmanSLO's Avatar
fordmanSLO
Could someone with a late 70's 351m/400 go and check what the part number is on the idle vacuum valve on their engine? It should be between the air bypass valve and the egr valve in back of the carb. Has on port coming out side, other coming out top, and backside has four little holes. This is the last part I need for smog and cant seem to find it. Thanks
Old Jul 12, 2001 | 04:27 PM
bubbaf250's Avatar
bubbaf250
fordmanSLO,
The part number for the '79 400 truck IVV (or EGR Control Valve) is D8TZ-9D473-B or D3OZ-9D473-A. The D3OZ part is obsolete, but the D8TZ is still available from Ford (for $64, ouch!).
Apparently, there are two different versions of the D8TZ part, so you need to look for the numbers on your existing part (if you have one now), either D8TE-B1A or D8TE-B2A. Any dealer should be able to get the part for you if you give them one of those numbers.
Good luck.
BubbaF250
1980 F250 4x4 Custom, 351M/NP435/NP208/D44HD-TTB/D60-FF/3.55s 6750 GVW, Rust & White.
Old Jul 13, 2001 | 12:15 AM
Ben_E's Avatar
Ben_E
AsianSpanker
'80-'86 FAQs (Frequently Asked Questions)
19
Mar 23, 2020 10:52 PM
tyler.dunn94
Nov 21, 2016 08:25 PM
eveready77
May 25, 2016 09:39 PM
rock15t
Aug 17, 2012 04:47 PM
Justin's Green Truck
1997 - 2003 F150
Jan 23, 2011 08:20 AM
