WOW!! 17 MPG.........I got all excited Saturday when after a 120 mile road trip I checked my MPGs and got 14.3 MPG. My truck is an 06 F-250 Reg cab, 2wd, 4:10, and a 6-speed manual. Now the 9 to 10 city MPG I can confirm matches mine.
I can get 17 MPG on my 03 F-450, 6.0 PSD, 4:30, 4WD, crew-cab if I keep it around 55 MPH. So I'm not saying 17 MPG with the V-10 can't be done. I just can't seem to do it.
I must say that I do enjoy pumping unleaded into the V-10 a whole bunch better than diesel into the 6.0.....
As of time of fill ups this morning Unleaded gas: $2.98 Diesel: $3.69 per gallon
I have an 08 lariat f350 4X4 sc srw 410 ls camper pakage & auto .I took a trip from Medford Oregon to Portland this weekend to pickup a tripple axle equipment trailer to haul a small bulldozer on. On the way there going 65 I got 13.8 mpg. When I only go 60 I have gotten 14.5 On my way back pulling the 3500 lb trailer I got 12.5 I had to order my truck to get the V10 and I'm glad I did.
radio flyer - 17mpg is great. The norm seems to be 12-14 on the highway. Is that 17mpg imperial gallons? About 14 miles per us gallon is equivalent to 17 miles per imperial gallons
USA regular, about 3.30 gal. 2008 v10 410 2wd F250XLT camper package SRW
everyone needs to inform on tranny - standard is going to get better on the highway.
new 08 cc 4x4 20 4.3 with 275 tires auto v10 - 9 city, 14 45-50, 13 65, 12 73 with 500 miles so far.
Um, I'm kind of confused as to how you figure that. How will a manual shift transmission achieve higher fuel economy on the highway than an automatic transmission in high gear with the torque converter locked??? According to the manufacturers, your theory is flawed.
i may be entirely wrong - i know on the psd 6.4 site the 6 speed manual is getting better highway milage - at least there is a trend i noticed over 5 months of reading that forum. i assume the 6 speed with the v10 would be the same - the ? is what rpm the 6 speed runs compared to the 5 on the highway. i assumed the 6 ran lower rpms. others have more knowledge on this site. i just know many felt the 6 speed was better at highway speed with the psd.
With the truck in my sig, 13.5mpg to 14.5mpg city/hwy mix, to/from work are very consistant numbers, 16mpg hwy is a no brainer.
I do not have 4X4, there are only 2 wheels out back on the one axle, and a stick to stir the gears. I ordered it that way, may be tough to sell down the road, but that isn't happening until there are 300,000 miles on the odometer. At least that's the plan anyway.
Even though some mfr's EPA tests show a given automatic vehicle as getting equal or better mileage than a stick, in real-life driving the reverse is often true.
If you have an identical final drive ratio, a stick will always get better mileage than an auto (even with a lockup torque converter in the latter) because the automatic is always leeching some power to run hydraulic pumps that do things like keep the truck in gear, lock up the converter, etc. Probably not a major diff on a V8 or V10, but this kind of stuff will always hurt a 4 cylinder car bigtime.
Even with the new autos that use solenoids for a lot of control functions, it takes electrical power to keep a solenoid activated, and that uses *some* horsepower thru the alternator....
