flat black over custom paint on mach 1
Old Feb 23, 2008 | 01:42 PM
v8xploder's Avatar
v8xploder
I have a 72 mustang mach 1 that i had painted about 6 years ago. its all one color, I want to have the side stripes and trunk stripes put back on here in spring which are a pinstripe or a sticker, if you will. The original mach 1s had a large portion of the hood painted flat black though. How hard or expensive would it be to have that done over my existing paint?
Old Feb 23, 2008 | 01:48 PM
blue68f100's Avatar
blue68f100
It's pretty easy. Just need to lightly scuff the surface so it will stick to the existing clear coat. Most do not clear coat the flat black.
Old Feb 23, 2008 | 01:54 PM
v8xploder's Avatar
v8xploder
Cool thanks, yea I was not planning on a clear coat over the black. SO this might not be too spendy for a paint shop to do? I suppose I would need to be careful washing that area then? or does the flat black stick pretty well?
Old Feb 23, 2008 | 06:55 PM
Ford150/428/dud's Avatar
Ford150/428/dud
The paint will stick very well, if you properly scuff the area that is going to be painted flat black.
Mask off the area to be painted and wetsand with some 1000 or 1500 paper. Give it a good wash and degreaser, then spray on your flat black.
Did I miss anything "Sorry im fairly new to body work, mostly because im only 17" Just ih case i left something out.
Old Feb 23, 2008 | 08:30 PM
BarryMc's Avatar
BarryMc
You can use a base coat clear coat system on the black, it's very durable and there's no problem washing it. PPG has a clear coat (DCU 2060) that is flat, but it's pretty expensive, there's also other paint companies that offer the flat clear coat. Just go to their websites and check it out.
Old Feb 24, 2008 | 03:26 PM
magusjinx's Avatar
magusjinx
The redneck way ...
Newspapers, masking tape and rattle cans ...
