Low fuel pressure. Suggest fuel sender problems....
Old Feb 8, 2008 | 01:42 PM
Pablo-UA's Avatar
Pablo-UA
Well, the quation is how to separate fuel sender lines and pull it out. Did it many times with aerostar, but I'm not sure how to do it with '01 ranger (4.0SOHC). I dont want to damage something...
Old Feb 9, 2008 | 09:38 AM
pawpaw's Avatar
pawpaw
Are you trying to remove the "fuel filter", or the in tank "fuel pump" on a 01 Ranger????
Old Feb 9, 2008 | 09:52 AM
Pablo-UA's Avatar
Pablo-UA
I try to pull tank pump.... strange fittings... how tho swparate them w/o damage?
Old Feb 9, 2008 | 02:17 PM
pawpaw's Avatar
pawpaw
Pablo, I've not had to remove a fuel pump, so I can't answer your question.
Maybe one of the guys that has done this on a more recent model will chime in with an answer, or perhaps someone on one of the fuel system forums would have the specific information you need.
Then again maybe the European Ranger has different fittings to the fuel pump, maybe Din fittings or such, that aren't used in the USA.
The manual I have for my 99, doesn't list anything unusual for the fuel lines.
Just a different locking ring, for the fuel pump on the "Super Cab" body style.
Old Feb 9, 2008 | 02:24 PM
aquanaut20's Avatar
aquanaut20
A special tool is available for unlocking the spring tabs in the fuel line fitting.
This will give you an idea of what to look for, kit has several sizes.
http://cgi.ebay.ca/ATD-5533-6-pc-DIS...QQcmdZViewItem
Old Feb 12, 2008 | 03:11 PM
seajay's Avatar
seajay
just did a pump on my '03 4.0 and, if yours are the same, just use something like a flat screwdriver to press in on the plastic spring-loaded retainer while keeping a little pull on the line. When finished, just push back on and give a tug to be sure they are caught.
Old Feb 12, 2008 | 03:25 PM
Pablo-UA's Avatar
Pablo-UA
OK, it is cold outdoors, when it will be a bit warmer, I gonna do all
Old Feb 12, 2008 | 03:56 PM
pawpaw's Avatar
pawpaw
Are you certain the fuel filter is ok????
A clogged filter will also cause low fuel pressure.
