1989 Ranger 2.3 8plug 2wd 5spd Tach Wire?
Old Feb 7, 2008 | 08:17 PM
4DS4EVR's Avatar
4DS4EVR
O.K. where do I hook up a tach on this little monster. It has the dual plug head. I can't stand driving a stick shift w/ no tach!!
One of my pet peeves....
Old Feb 8, 2008 | 07:22 AM
jason867's Avatar
jason867
I believe most tachs have 4 wires. One is pos+, one is ground, one is for the backlight, and the other hooks up to your coil
I believe most coils have the spot marked "tach" that you need to plug into.
I forget the coloring of the wires, though, the tach papers may tell you, and I know there's someone on here that knows them...
Old Feb 8, 2008 | 09:56 PM
4DS4EVR's Avatar
4DS4EVR
My truck has DIS so there is no where I can see to hook it up
Old Feb 8, 2008 | 10:40 PM
RangerPilot's Avatar
RangerPilot
I belive it's tan/yellow for the tach wire in the Ranger. For some reason that jumps out to me.
Should be a tach wire in the main harness going into the truck, even if your truck didn't come stock with a tach, so you could just find the wire and tap into it.
Old Feb 10, 2008 | 02:07 PM
4DS4EVR's Avatar
4DS4EVR
Is the wire under the dash or on the firewall above the wiper motor?
Thanks in advance.
Old Feb 10, 2008 | 08:01 PM
RangerPilot
Both under the dash, and under the hood in the large plug that connects the underhood wires to the in-cab wires. Wherever you can find it.
Old Feb 11, 2008 | 05:27 PM
4DS4EVR's Avatar
4DS4EVR
Thanks, do you mean tan with yellow stripe or just a tannish yellow color?
Sorry for all the questions, I don't want to hook it up to the wrong wire.
Old Feb 11, 2008 | 06:02 PM
RangerPilot
Okay forget the tan/yellow wire. That seems to be wrong.
I can't seem to find the wire in the wiring diagram. I might be just missing it.
http://www.autozone.com/images/cds/g...3d800f947e.gif
Old Feb 12, 2008 | 04:29 PM
4DS4EVR's Avatar
4DS4EVR
Just in case anyone else is attempting to hook up Tach in there old POS ranger. I e-mailed Autometer and the tech line said the wire I need to connect to is the Black w/ yellow stripe coming from the ignition module.
Thanks RangerPilot for all your help.
Old Feb 13, 2008 | 11:30 AM
RangerPilot
Very cool, sorry about missing the wiring color.
Tach functions well I assume? You happy with it?
Old Feb 13, 2008 | 09:16 PM
4DS4EVR's Avatar
4DS4EVR
I havent hooked it up yet, but I will post a pic asap. I am flush mounting it where the auto 4X4 switch goes. it should look pretty cool.
Old Jun 5, 2008 | 07:07 PM
Headlessmunky's Avatar
Headlessmunky
I have the same truck and problem My question is can i just splice into the wire anywhere?
rowdyredneck
Aug 3, 2013 10:45 AM
98clifford
1997 - 2003 F150
Nov 9, 2011 09:09 PM
Old Hickory
Feb 26, 2011 08:39 AM
IDfordguy
Sep 26, 2005 01:00 PM
GendoIkari69
15
Apr 28, 2002 07:05 AM
